Is there a way to divide a panel edge without dividing the edge on the opposite side of the panel?
Is there a way to join panel edges that have been divided?
Solved by Artur.Kosakowski. Go to Solution.
Here you are.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
How to select panel edge? When I click on edge, only whole panel selected
Hi @Anonymous
Try these steps:
Please try to divide top edge for this one in atteched file
H @Anonymous
I assume that what you really want is the control over meshing. If so try these steps:
I am not sure you can do that because that edge is an arc segment.
What you can do is redo the panel increasing the numer of sides on arc discretization.
Rafael Medeiros
Hi @Rafacascudo
The similar effect can be obtained in this way:
Yes , sure , That´s what I meant by "redo"
Rafael Medeiros
Hi, i tried dividing a wall in order to obtain better discretization of linear reactions, but it´s not working:
After aplying the Divide Tool to the edge and assigninn distance = 1m, nothing changes. I´m using a Wall with Shell model calculation.
Please i would appreciatte some help, my posts generally are not answered.
Thanks!.
unmark "generate... "
Rafael Medeiros
I did, but dindn´t succeed. Model atacched in case you wanna check.
Thanks.
set the "divide" dialog as shown,select/click the desired edge to be designed and it will ask you if it is the edge or the whole panel(all edges) to be divided . select the edge and click OK.
Rafael Medeiros
