Hi, I would like to know what type of deflection does robot display in this Panel Map Criteria.
Image Attached.
I would also like to know if Robot Can display Crack Widths?
Solved by Rafal.Gaweda. Go to Solution.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Thanks for the reply.
But im pretty curious with the crack width display here. see attached image.
its stuck at 0.3mm, does that mean robot adjusted the steel requirement to satisfy 0.3mm crack width settings?
