Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel Deflection and Cracking
4 REPLIES 4
935 Views, 4 Replies
Hi, I would like to know what type of deflection does robot display in this Panel Map Criteria.
Image Attached.
I would also like to know if Robot Can display Crack Widths?
4 REPLIES 4
Romanich
You can get the Crack Width after calculation of the required reinforcement.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
in reply to: Romanich
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks for the reply.
But im pretty curious with the crack width display here. see attached image.
its stuck at 0.3mm, does that mean robot adjusted the steel requirement to satisfy 0.3mm crack width settings?
Tags (2)
Rafal.Gaweda
Seems so if your settings are like this :
Rafal Gaweda
