Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel Cuts Results
5 REPLIES 5
sunwaymas
1253 Views, 5 Replies
Panel Cuts Results
Below is a diagram showing results from a "Panel Cut". It only gives global extreme values. How do I get it to give intermediate results as well similar to "local peak results", for example the Bending Moment in the top slab.
Thanks.
5 REPLIES 5
dimogrec
in reply to: sunwaymas
I don't know if there's a way to show more values directly on the diagram (as you can for bar elements), but you can use diagram analysis to open the cut in a new window and read the values in any point.
sunwaymas
in reply to: dimogrec
Thank you so much 🙂
jakobbruhl
Sure would be nice if this was available as data output
Rafacascudo
in reply to: jakobbruhl
Instead of one single panel cut ,you can create a series of consecutive cuts covering the total lenght of the original panel cut , and then have several diagram values (max and min per cut) displayed
Rafael Medeiros
jakobbruhl
in reply to: Rafacascudo
Thank you for the suggestion. Like the other workaround I've used ("Diagram Analysis" from the "Cuts" tab on the Panel Cuts menu), this is tedious. Knowing that the data is present, it seems it would be an easy addition to the potential outputs to provide a table of this data.
