One question about reduced results in panel cuts, I use it to get the total results for a set of walls, for foundation design. The problem is that i need to hand copy the result from screen to a table... I know its possible to get the results from a panel in a table (reduced result), but is it possible for a set of panels?
thanks.
Yes, you can display only selected panels. This table works in the same way as any other e.g. Bar forces one. In addition you can decide which cuts (e.g. tops or bottoms) you want to see.
