Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
faisal.aaouatif
663 Views, 5 Replies
panel cut
when using panel cuts , we can study a hole moment diagram for a slab for example.
but , is there any way to extract quickly (automatically) values of moments in defined points (regular distribution of points) belonging to a cut ?
Thx
5 REPLIES 5
See below
Rafal Gaweda
Thank you Rafal ,
Moving the mouse cursor over the diagram gives all the values needed.
to clarify my past question , i give the example below :
defining moments on Slab cut with 10 m long : instead of pointing twenty times ( every 0.50m ) the mouse cursor over the moment diagram , is there is a way ( table ) in whish we can have moment values every 0.50m.
Thank you
I am afraid there is no such option.
Rafal Gaweda
OK
Thank you VM
Here is a hint for you:
- select the nodes that lie on the cut (or nodes close to the cut)
- show FE results, select the internal forces of interest
- filter the results to show only results for the selected nodes
- copy the filtered results to a spreadsheet program
P.S. Be careful of the order of the filtered results in the table. It might need slight reordering to match the node numbering in the cut.
Cheers
