Panel cut table
Panel cut table
Hi
It would be very helpfull to be able to get panel cuts in table and the ability to copy a panel cut. For instance if you have different models with the same geometry it would be fast if you where able to copy panel cuts into a model.
And also to see the results from more than 14 panel cuts at a time.
Also it would help a lot if you could get more than one result at a time. If you need to check both top and bottom envelope.
4 Comments
I second the suggestion in the post above. If a panel cut input table be provided for example with
1. start - end coordinates
2. type of output  - mxx/complex mxx etc
3. type of smoothening
4. cut name
etc in a table.
We end up comparing panel cuts acorss various iterations of a fairly large model across many locations and it may help just copying pasting the cut definitons across mulitple robot files. It takes up quite a bit of time to draw all the cuts again. Furthermore it will be nice to sort panel cuts by name in robot .Just a wish. Thank you
Regards
philip.s
Status changed to: Gathering Support
prior status deleted, setting to default
SerhanB
Exporting panel cuts info to an external file (which can be imported back to another model) would be a very handy feature!
jakobbruhl
Please! This would be very helpful in the design of reinforced concrete structures. The data from the panel cuts can be used to determine bar cut-off locations. Without the data being provided in a table form, there is wasted time (and potential error introduced) in reading and recording specific points from the panel cut using the "diagram analysis" feature.
