I created a panel without any bars. I put the forces and FE meshing, and them I caculated. That's is allright. The problem I need the moments at a certain distance from the highest moment. So I did a panel cut and I got something like this:
And now how I got the moments values at, for exemple, 1 metre from the moment M=457.96 kNm?
I'm sorry for my English but that ins't my native language.
Solved by Rafacascudo. Go to Solution.
Solved by HoshangMustafa. Go to Solution.
Hi
Rather I would use a perpendicular cut plane at a certain distance from the highest moment.
You can follow HoshangMustafa sugestion , or you can use " diagram analysis" ( Panel cuts / Cuts tab) to find the moment values along the cut.
Rafael Medeiros
