Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel contour points modification (API)
26 REPLIES 26
Message 1 of 27
sergey.churilov
2410 Views, 26 Replies
Is there any way to present panel contour points (coordinates X, Y, Z) in a table like the table available for nodes?
I do not want table for each individual panel, but a table which presents all contour points for all defined panels in a model on one sheet.
This could be helpful for fast correction of the contour points coordinates, especially in cases without precise geometry where the 9th decimal place at a coordinate makes all the difference between a good or bad mesh.
26 REPLIES 26
Message 21 of 27
Rafal.Gaweda
in reply to: t.sautierr
Ordinary rounding, rounding up and rounding down in attached xls
(choice by radiobuttons on top)
Rafal Gaweda
Message 22 of 27
t.sautierr
in reply to: Rafal.Gaweda
Thx Rafal!
Is it possible to have your source code of the round up addin (the one with .dll)
This one is even more better as it can round also bars coordinates and points. I'd like to implement the round up and down in it.
Thanks again.
Message 23 of 27
Rafal.Gaweda
Yes, I will post it as soon as possible.
I have already implemented Up and Down in it.
Rafal Gaweda
Message 24 of 27
Rafal.Gaweda
Message 25 of 27
Rafal.Gaweda
Update
Faster objects update
Rafal Gaweda
Message 26 of 27
colm.morrin
Hi. I am constantly getting inconsistent mesh errors with panels drawn over .dwg backgrounds. I was hoping that your macro would prove to be the solution to this but I'm getting an error when I try import the panels into the excel sheet (see attached photo). Any idea how to fix this? Thanks, Colm
Message 27 of 27
Rafal.Gaweda
in reply to: colm.morrin
Check this thread:
http://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geometr...
If it does not help please tell me which Robot version do you use and post Robot file to check it
Rafal Gaweda
