Discussion Groups
Robot Structural Analysis
Valued Mentor
tony.ridley
Re: Panel contour points modification
04-13-2012 08:11 AM in reply to: sergey.churilov
This is the problem with Rafal's spreadsheets.  Every time one comes along, it makes you want more!
Please use plain text.
Valued Contributor
sergey.churilov
04-13-2012 09:11 AM in reply to: tony.ridley
Hahaha :smileyhappy:
I tried ROS 7 years ago, but I was not able at that time to do something. Since this lovely sheet, my interest has grown.
Pls, do not forget to upload your updated sheet on Monday.
Valued Mentor
tony.ridley
04-14-2012 07:25 AM in reply to: sergey.churilov
Ok, I've uploaded my spreadsheet hack of Rafals' original one.
Sorry if my VB coding is a bit schoolboy style.
It works like this.  You can select to either fix the number of decimal points, or additionally include rounding of the data by inputting into the orange coloured cells.
If you are happy with the rounding click accept rounding.
Then click update Robot model
Tony
Valued Contributor
sergey.churilov
04-14-2012 11:44 PM in reply to: tony.ridley
Thank you Tony for the file.
Can you please save the file in Excel 2003 version also?
Valued Mentor
tony.ridley
04-16-2012 01:20 AM in reply to: sergey.churilov
Product Support
Rafal.Gaweda
04-17-2012 06:08 AM in reply to: tony.ridley
Thanks to Tony's modification I have modified macro to work on selected (by checkboxes) coordinates directions.
Rafal Gaweda
Valued Contributor
sergey.churilov
04-17-2012 06:12 AM in reply to: Rafal.Gaweda
Thnaks Rafal.
You are doing great job.
t.sautier
03-20-2013 01:59 AM in reply to: tony.ridley
I have found you nice spreasheet to round up panel counter Rafal.
I tried to use it :
importing coordinates -> not a problem
I modify some coordinates and then I try to update -> I get a the attached error.
I assume it is a misuse, can you help?
Thx
Product Support
Rafal.Gaweda
03-20-2013 07:10 AM in reply to: t.sautier
Attached macro will work notonly with English robot interface.
Rafal Gaweda
t.sautier
03-20-2013 07:51 AM in reply to: Rafal.Gaweda
Same macro with the rounddown function.
This avoid the problem for example :
point 1 : X=6.217 -> rounded 6.22
point 2 : X=6.212 -> rounded 6.21    ---> problem
rounddown will make 6.21 in both case.
NOTe : could be roundup ....
Rafal, I'd like to implement this in the extra addin you given to us (with this .dll ou .exe) could please either modify your addin or give us the code.
I prefer your addin as it works on nodes, panel and bars and not only pannel like in the excel sheet
Thanks again.
