Discussion Groups
Robot Structural Analysis
Valued Contributor
sergey.churilov
Panel contour points modification (API)
562 Views, 23 Replies
04-12-2012 10:51 PM
Is there any way to present panel contour points (coordinates X, Y, Z) in a table like the table available for nodes?
I do not want table for each individual panel, but a table which presents all contour points for all defined panels in a model on one sheet.
This could be helpful for fast correction of the contour points coordinates, especially in cases without precise geometry where the 9th decimal place at a coordinate makes all the difference between a good or bad mesh.
Please use plain text.
Valued Mentor
tony.ridley
Re: Panel contour points modification
04-12-2012 11:16 PM in reply to: sergey.churilov
Product Support
Artur.Kosakowski
04-12-2012 11:20 PM in reply to: sergey.churilov
No, this is possible only for one panel at a time but I would suggest considering the use of the detailed correction option and adjust the model either structural axes or indicated planes instead.
See e.g. http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Detailed-Correction/m-p/3079956
Artur Kosakowski
Valued Contributor
sergey.churilov
04-12-2012 11:55 PM in reply to: sergey.churilov
@Tony
Hi Tony, I have been reading many of your post and I found out that we have come to the same problems in using Robot. I have been using Robot for 10 years, but some of the questions/problems still remain unsolved even in the latest releases.
Anyway, I will try and use the macro excel file that were provided and let you know my experience
@Artur
This option works sometimes, but not always. The problems about contour points misalignment still remains on some panels.
Valued Mentor
tony.ridley
04-13-2012 07:04 AM in reply to: sergey.churilov
I run the spreadsheet in the link, but I add a few columns to fix the rounding issues.
ie =fixed(cell,3)
then i replace the original columns in the spreadsheet before I hit update.
I use it on an almost daily basis and find it works really well.
Tony
Product Support
Rafal.Gaweda
04-13-2012 07:26 AM in reply to: tony.ridley
Is this general improvement? If so maybe we can update xls ?
Rafal Gaweda
Valued Mentor
tony.ridley
04-13-2012 07:32 AM in reply to: Rafal.Gaweda
If the problem where rounding of decimal points for node co-ordinates is not linked to the user defined job units is not fixed in future Robot versions, then yes.  (sorry still havn't used 2013)
If not, then the spreadsheet needs an update to include a rounding feature.  I have already done this though, shortly after you provided it.  This panel geometry sheet you made is one of my favourites.  Gets used almost daily.
Tony
Product Support
Rafal.Gaweda
04-13-2012 07:45 AM in reply to: tony.ridley
Rounding is not impemented but... thru API it can be done.
I will see. :-)
Nice to hear that.
Update xls and share.
Rafal Gaweda
Valued Mentor
tony.ridley
04-13-2012 07:58 AM in reply to: Rafal.Gaweda
Yes Sir.
Monday!
too late on Friday now to make the brain do this
Valued Contributor
sergey.churilov
04-13-2012 08:09 AM in reply to: tony.ridley
Please do so. I tried the sheet provided in the other post.
It works perfectly. Its a miracle. Thank you so much.
BTW is there any Robot open source manual or tutorial available to download?
This just imposed many ideas I would like to implement for other analysis needs.
