Does anyone know a way to obtain a table of all panel coordinates in a model?
It is frustrating to try and track down where mesh inconsistencies are occuring by clicking on every panel in the model and checking that the geometry is in fact correct.
Cheers,
Tony
Solved by tony.ridley. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Hi Tony,
Rafal on holidays:(
I have just checked in 2013 version the spreadsheet Rafal submitted in this post - works without problems.
Can you check in Task Manager whether only one robot.exe process is running. If more than one close Robot, close all left processes and restart Robot.
If it doesn't help please check which version of Robot API is registered:
