P-delta analysis
4 REPLIES 4
MohammadZaman
3108 Views, 4 Replies
P-delta analysis
Hello.
I want to take account p-delta effects in DL+LL combination and modified stiffness matrix under this combination and take effects of p-delta to other combinations (Like buildings code). Is there any option to do this?
Thank you.
4 REPLIES 4
Pawel.Pulak
in reply to: MohammadZaman
It is not quite clear what you want to do.
1/ If you want to assign or modify nonlinear p-delta analysis to several load cases and combinations then it can be done using the bottom part of Analysis Type window:
2/ If you want to use some nonlinear combination as the starting condition for other load cases (incrementing load basing on some already applied load) it is not possible to use combination as a starting case. Only the first simple case can be used as the starting one - see the screen capture below.
The workaround is to use in the first simple load case all loads contained in the combination
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
amirdj.gc
i might be out of subject but i would really ask about how to view the P-DELTA analysis results in RSA.
Pawel.Pulak
in reply to: amirdj.gc
There are no results specific for considering geometrical non-linear 2nd and 3rd order effects  in RSA ("Non-linear" and "Non-linear P-delta" in RSA settings) - the same results as for any static linear analysis are available.
The possible influence of non-linear geometrical effects  is in values of forces, moments, reactions and displacements comparing to static linear analysis results.
Some additional information and simple example can be found in  this forum post:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-analysis-P-delta-analysis/m-p/364...
Regards
Pawel Pulak
Dear Pawel
what is the difference between them?
which type of analysis we change it to Pdelta analysis ? Its for simple case or for simple case and combination ?
