Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Overlap Panel
3 REPLIES 3
jrandeep
2080 Views, 3 Replies
Overlap Panel
I have problem with Overlapping panel. when I generate the model, I am getting this warning.
But when I check panel manually they are OK.
Could you rectify this Issuse, I have attached the model to the following link
https://onedrive.live.com/redir?resid=75D8A1AF15EB60B4!15660&authkey=!ABy9EKSZ56iyD04&ithint=file%2c...
BR,
J.Randeep
3 REPLIES 3
Rafal.Gaweda
in reply to: jrandeep
See below
Rafal Gaweda
in reply to: Rafal.Gaweda
is the tolerance in analysis type smaller the better or larger the better? I also encounted similar problem. Thank you
Rafal.Gaweda
With standard structure size use 1 or 2mm tolerance
Rafal Gaweda
