it is possible see in the model the shape of a thickness orthotropic like a corrugated plate for example
thanks for the help
Solved by AhmedZA. Go to Solution.
It is not possible.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
like i said before thanks for your answer, but even if i use a orthotropic thickness like a slab on trapezoid plate, i answer it cause i see a model with this kind of panel and see it the shape of the thickness, thanks
THANKS FOR YOUR ANSWER, BUT I MEAN THE SHAPE OF THE PANEL , SEE THE "REAL SHAPE " OF THE THICKNESS, THE DRAWING OF THE THICKNESS
