Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Orientation of beams / Orientation des poutres
5 REPLIES 5
575 Views, 5 Replies
Hello
I would like to represent my autocad drawing on Robot
The problem is that the beams are not represented in the same direction as my drawing Autocad.
What should I do?
thank you
_____________________________________________________________________________________________________
Bonjour
j'aimerai représenter mon dessin autocad sur Robot
Le problème est que les poutres ne sont pas représentées dans le même sens que mon dessin Autocad.
Que dois je faire ?
Merci
5 REPLIES 5
Rafal.Gaweda
I guess you have created such double section either by loading double section from database or from Compound tab from New Section window. So as you can see these single profile are set vertically, not horizontaly as you want.
You can model these elelemets as two separate bars or create such compound section in Section Definition (Section Builder) module.
Rafal Gaweda
in reply to: Rafal.Gaweda
No i want to have only one bar and for this, i want to make 2 HEB240 like in my autocad's picture.
You say :
I need to do a section HEB240 but with The Ax, Ix, Iy, Iz of 2 HEB 240...... ?
Rafal.Gaweda
See below
Rafal Gaweda
i do my model but where i can find it to use it for my section.
my file saved is like poutre.sec i think it's ok but after this what i need to do ?
Merci beaucoup
Rafal.Gaweda
No, you have to save this section to database
then in Robot load it, as every database section, from the database you saved to
Rafal Gaweda
