Hi
Occasionally it happens that a new panel cut gets introduced in the midlle of existing panel cut list. Is there an option to sort the panel cuts by "name" or to change the sequence in which the cuts are displayed. Any insight into why the last creat panel cut does not appear at the top always will also be helpful.
/Regards
PS: In the attachment, cuts B-Mx-6/7 were defined after 5 and cut B-My-1 was defined last. Though they were not defined in the same session.
