Hi sirs
I have large strucutre model . Can you help me to get only reaction of structure model and export to a new model of robot to analysis and design only raft foundation?
Note : When i saved the raft as (Substructure) , I couldnt do any changes such as (elastic coeficient value). because i will lose every thing .
Refaat
Solved by Refaat. Go to Solution.
Rafal is it possible for you to make a new edition with 2 buttons instead (Read old + write to new)
I would like to have the possibility to edit some of the reactions before loading them into the new model.
Sorry to come back to this old thread.
I did try your macro to get reactions in the source model as forces in the target model, but without succes.
The target model is only the 4 supports, which i'll use to add them a raft.
A simple structure is attached
