in the name of GOD .
hello ta all.
in attached picture I draw a one-way slab in left and draw a two-way slab in right. (see attached picture.)
questions :
1 ) how can I understand which slab is one-way & which slab is two-way from appearence of those and without properties windows of those ??
2 ) how can I understand the direction of load transfer of one-way slab from appearence of that and without properties window of that ?? (for example in attached picture, what's the direction of load transfer of one-way slab (on x or on y direction ) ?
3 ) how can I rotate the direction of load transfer of one-way slab ??
thanks beforehand for your appropriate answers...
best regards.
Mohammad
Solved by Rafal.Gaweda. Go to Solution.
Re1
Re 2
Re 3
Hi
I didn't get your answer to question 2. Can you explain with a photo?
