Offset Deflection Problem
3 REPLIES 3
ByrnePM
566 Views, 3 Replies
Hi all,
I am trying to apply an offset for a simple connection of a beam to column (See Fig 1 and 2 below). This is in order to simulate the eccentric loading at the connection between beam and column (large UB sections are being used for the columns).
After applying the offset and analysing the structure, the deflections of the beams and columns at the location of the offset have increased hugely, (the offset has lead to a mechanism being formed? ) see Fig 3 below.
Does anyone know the possible reasoning behind this ?
3 REPLIES 3
Artur.Kosakowski
in reply to: ByrnePM
My understanding is that without these offsets the results are as expected - is this correct? If yes, have you ignored any displayed warnings? If not, could you attach the model?
Artur Kosakowski
ByrnePM
in reply to: Artur.Kosakowski
Yes Artur, the results are as expected without the offset applied (see Fig 1 below).
No warnings are displayed during the analysis of the structure.
Artur.Kosakowski
First of  all mind to display exact deformations rather than deformations when you have such definitions of offsets. In addition I would remove the releases for inclined columns so to avoid the situation that all bars which meet in the common node have bending releases defined (and then of course I would check the value of bending moments for the bars  deleted the releases from 🙂 ).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
