Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
209 Views, 1 Reply
Off line panels
I was trying to use the structure merge function to combine 2 models to 1. However, after doing this, I found a lot of off line panels (panels not coinciding with one another). I've tried to fix this by redefining overlapping panels, but as you can see from attached picture, it doesn't always work. All 4 panels go haywire eventhough the geometry met in 1 point. This gives me meshing problem. Any way to fix this?
Thanks.
1 REPLY 1
Rafal.Gaweda
Run
- Detailed Correction, to Plane
or
 - define structural axes, then Detailed Correction, to Structural Axes
or
- find on this forum either Roundup addin for robot then run it, or xls for correction objects coordinates
or
- send us file to check.
Rafal Gaweda
