Here's a screenshot:
Notice how at the midspan the moment labels suddenly go from 3034.48 to 1886.66, but the beam options diagram shows the correct behavior, which is nice and well-behaved.
I have not yet installed Service Pack 3, which I saw came out today but havent had the time to actually install.
The model can be seen here: https://dl.dropboxusercontent.com/u/3087637/JacareiTest.rtd
Solved by Artur.Kosakowski. Go to Solution.
Mind that you display values for top and bottom envelopes at the same time. This filter (combination +/-) is intended for the tables.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
