Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Object Combinations
3 REPLIES 3
veronica.revilla
742 Views, 3 Replies
Object Combinations
Please could somebody explain how to successfully combine the two pipes (combine panels 14,15,16, 19 with panel 😎 in the attached model? Have tried various object combination methods (including the examples on previous posts in the forum) but nothing seems to work for me.
Thanks in advance..
3 REPLIES 3
I guess objects 14to16 19  should be made as a one "cone".
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
1. Cone tube as a Cone
2. Bottom shaft cylinder as cylinder with 128 circle divisions
Check attached file, check thicknesses, remove temporary bars
Rafal Gaweda
Hi Rafal.
Thanks for your help. I think I understand now. Will just have to change it slightly as the walls of the vertical cylinder should be sloped, so I assume that modelling this as a cone (similar method to the inlet pipe) should be ok...
Thanks again.
