Hello Robot users,
I'm using the numbering tool in order to tidy up my model a bit because since the first time I built it, I've made some changes, deleted some parts and added others.
I have attached two pictures, the first one is a numbering and Robot gives by default (i.e. standard numbering) and the second one is the desired numbering I would like to achieve.
I've got to this after several steps using the geometrical numbering and I would like to know whether there is a way of doing this in one only, quick step?
Thanks in advace for your help.
sanjuan100
Solved by Artur.Kosakowski. Go to Solution.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
