I'm struggling to find out how to normalize the eigenvectors for a group of nodes to 1 in tabular format. I have:
The maximum should reach 1 although for some reason it isn't normalizing and giving an exact value. Do you know how to change this?
Thanks.
Ben.
Solved by Artur.Kosakowski. Go to Solution.
Solved by Pawel.Pulak. Go to Solution.
Unfortunately it is not possible to normalize buckling eigenvectors to 1 inside Robot (the improvement request for it is registered for some time). Such functionality exists in Robot only for vibration eigenvectors (dynamic modal analysis).
The workaround is:
1/ change the format of displaying eigenvectors to display more than 0.0 - increasing the number of decimals and/or changing to scientific (exponent) in Tools>Job Preferences>Units and Formats>Other>Displacement
2/ exporting to for instance MS Excel
3/ normalizing to 1 there
It was already discussed in this forum post:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Buckling-Analysis/m-p/3797580#M11292
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
In RSA 2016 the eigenvectors for buckling analysis are by default displayed with the normalization to 1 with no change in the UI.
