Hi
Could you tell me if Robot can check nonlinear analysis in reinforced concrete models? I know that Robot has calculated something but I can't find any information if it has checked creeping and fissuring.
Thank you
These options are in Design module. Will it work in normal static when I'll change it there? I need forces in the truss because I have to check second order effects. I need to know if Robot check creeping and fissuring in nonlinear analysis because without them it will be incorrect with Eurocode 2.
Another problem is that Robot has got problems with imports the truss from geometry to design. It has divided the truss to groups of beams without any logic (it looks like snake not rods).
No.
There is no such option in Robot.
You can select some bars or bars and connecting (common node) to import them to Steel Connection module and then you will see the logic.
You can select all bars and then go to design module. I think it works well with typical frames where every level of construction is one floor (and columns between them). Probably it has problems with a truss because it is one element with a lot of levels. I don't try it with frame but I can see how it divides a truss.
