Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Non-linear supports wit different behavior in tension and compression
1 REPLY 1
284 Views, 1 Reply
I tried to create a non-linear support introducing the points from excel, in order to obtain the graphic presented in the figure 1 but then, after I clicked OK, the program automatically changed graphic shape and marked the SYMMETRY box as it is shown in the figure 2.
Is there any possibility to create a non linear support as the one presented in figure 1?
Thank you,
José Soares
figure1
figure2
1 REPLY 1
Pawel.Pulak
See the screen capture below. The main point to notice is that when "negative semi-axis " is active the opposite sign of values is automatically added during input. So for instance the input of 2; 2.5 results in the point -2; -2.5 on the diagram.
Moreover when using export or import of functions:
1/ it works separately for positive and negative semi-axis
2/ the rule related to opposite signs for the negative semi-axis is applicable here too
3/ values in *.fun file are in m, N (meter, Newton) units independently from length and force units active on the diagram
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
