Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Non linear support
13 REPLIES 13
Message 1 of 14
689 Views, 13 Replies
Non linear support
I would need some help on this model please. I would like to define non linéar supports that would maintain the structure only in one direction (when the horizontal effort is is "compressing" the structure against the support) and would be null for the other way (when the horizontal effort is "pulling" the structure).
Herewith please find the model i'm talking about.
Gratefully,
Fouzi
13 REPLIES 13
Message 2 of 14
Artur.Kosakowski
Artur Kosakowski
Message 3 of 14
Thanks for your answer,
I tried it but it tells me that the calculation doesn't converge.
I've tried to put these supports in UX+ and UX-, it nerver converges.
Message 4 of 14
Artur.Kosakowski
For UX+ it is only for case 3 which is wind load. As it doesn't act alone the convergence of this load case is irrelevant as long as all defined combinations converge.
Case 1 : Poids propre pierre
Analysis type: Static - Nonlinear
Non-linear process: convergent.
Maximum value of process parameter when convergence is obtained : 1.000
Maximum value of process parameter when convergence is not obtained : 1.000
Case 2 : Vent en pression
Case 3 : Vent en depression
Non-linear process: divergent.
Maximum value of process parameter when convergence is obtained : 0.975
Case 4 : ELU 1 (1,35 PP)
Analysis type: Nonlin. Combination
Case 5 : ELU 2 (1,35PP+1,5VP)
Case 6 : ELU 3 (1,35PP+1,5VD)
Case 7 : ELS (PP+VP)
Case 8 : ELS 2 (PP+VD)
Artur Kosakowski
Message 5 of 14
So you're telling me, even if it doesn't converge, I'll have the right results?
Message 6 of 14
Artur.Kosakowski
The results for case 3 (divergent are wrong) but the results for combinations (convergent) are correct but my assumption is that the reason you created the combinations is that you don't have case 3 acting on the structure alone. If yes, the fact it converges or not  is not important as you need to have the results for the combinations only. In other words simple load cases could only be the treated as definitions of loads and not calculated at all.
To put it in yet another way: if you have unidirectional support that doesn't work if you pull it and then you actually pull it (case 3) you probably don't expect to have the convergence (right results), don't you? Smiley Happy
Artur Kosakowski
Message 7 of 14
I see... Thank you for your answer!
How could I, please, set simple cases as definition loads so they aren't calculated?
Message 8 of 14
Artur.Kosakowski
Artur Kosakowski
Message 9 of 14
in reply to: Artur.Kosakowski
Thanks a lot!
Message 10 of 14
Still not working! 😞
I still have negativ supports where they should be null... 😞
Message 11 of 14
Artur.Kosakowski
Attach the modified model please.
Artur Kosakowski
Message 12 of 14
Thanks.
Message 13 of 14
Artur.Kosakowski
Artur Kosakowski
Message 14 of 14
Thanks a lot!
Now It works perfectly!
