Discussion Groups
Robot Structural Analysis
Distinguished Contributor
Tuctas
Non-linear releases
264 Views, 5 Replies
10-17-2012 12:31 PM
  I would like to ask about the “non-linear releases” in Robot.
  By using non-linear releases:
  Can we obtain a capacity curve when making a push over analysis?
  Is the user able to obtain the plastic ratio and/or generally view the plastic state for each increment?
  Which are the differences comparing with the non linear hinges?
  Thank you.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Non-linear releases
10-18-2012 02:30 AM in reply to: Tuctas
No
No.
Different way of definiton , different locations.
Rafal Gaweda
Tuctas
10-18-2012 04:15 AM in reply to: Tuctas
  Thanks for ther reply.
  As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
  Furthermore, in which way are we able to view-display the non-linearity of the behaviour in case of using non linear releases?
Product Support
Rafal.Gaweda
10-19-2012 12:51 AM in reply to: Tuctas
Hope so.
Only by looking at forces, moments, stresses results.
Rafal Gaweda
Tuctas
10-19-2012 05:30 AM in reply to: Rafal.Gaweda
  Question: As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
  Answer: "Hope so."
  It will be helpfull If anyone that has made any kind of invsetigation and has come to any conclusions about this issue to let us know.
Tuctas
10-22-2012 09:44 AM in reply to: Tuctas
  After testing a simple cantilever, the results are identical.
