I would like to ask about the “non-linear releases” in Robot.
By using non-linear releases:
Can we obtain a capacity curve when making a push over analysis?
Is the user able to obtain the plastic ratio and/or generally view the plastic state for each increment?
Which are the differences comparing with the non linear hinges?
Thank you.
No
No.
Different way of definiton , different locations.
Thanks for ther reply.
As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
Furthermore, in which way are we able to view-display the non-linearity of the behaviour in case of using non linear releases?
Hope so.
Only by looking at forces, moments, stresses results.
Question: As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
Answer: "Hope so."
It will be helpfull If anyone that has made any kind of invsetigation and has come to any conclusions about this issue to let us know.
