Non-linear releases
5 REPLIES 5
Tuctas
457 Views, 5 Replies
Non-linear releases
  I would like to ask about the “non-linear releases” in Robot.
  By using non-linear releases:
  Can we obtain a capacity curve when making a push over analysis?
  Is the user able to obtain the plastic ratio and/or generally view the plastic state for each increment?
  Which are the differences comparing with the non linear hinges?
  Thank you.
5 REPLIES 5
Rafal.Gaweda
in reply to: Tuctas
No
No.
Different way of definiton , different locations.
Rafal Gaweda
Tuctas
in reply to: Tuctas
  Thanks for ther reply.
  As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
  Furthermore, in which way are we able to view-display the non-linearity of the behaviour in case of using non linear releases?
Rafal.Gaweda
in reply to: Tuctas
Hope so.
Only by looking at forces, moments, stresses results.
Rafal Gaweda
Tuctas
in reply to: Rafal.Gaweda
  Question: As concerns the 3rd question: if the location and the function are the same, is the behaviour-responce also the same?
  Answer: "Hope so."
  It will be helpfull If anyone that has made any kind of invsetigation and has come to any conclusions about this issue to let us know.
Tuctas
in reply to: Tuctas
  After testing a simple cantilever, the results are identical.
