incorrect use of a release for truss member ( only non - linear release for UX direction are admissible ). i can't not solve this problem.
Solved by Artur.Kosakowski. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Solved by t.sautierr. Go to Solution.
Trusses are working only in tension/compression so I assume it is not logical to make other releases as it included already in the type of structure you use.
If you turn your structure type into frame i think your error will disappear.
I have the same problem..
Frame 3D, bars without releases, tension only.. it gives this message. Why?
Hi @c.lucchetti
Delete the fixed - fixed releases from these bars.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
