Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
non - linear release for UX direction..
6 REPLIES 6
huynhhoangvt
3250 Views, 6 Replies
incorrect use of a release for truss member ( only non - linear release for UX direction are admissible ). i can't not solve this problem.Untitled.png
6 REPLIES 6
t.sautierr
in reply to: huynhhoangvt
Trusses are working only in tension/compression so I assume it is not logical to make other releases as it included already in the type of structure you use.
If you turn your structure type into frame i think your error will disappear.
Rafal.Gaweda
Delete releases from truss bars.
IF not - send us model to check.
Rafal Gaweda
c.lucchetti
in reply to: Rafal.Gaweda
I have the same problem..
Frame 3D, bars without releases, tension only.. it gincorrect use of releases.PNGives this message. Why?
Hi @c.lucchetti
Could you zip and attach the model?
Artur Kosakowski
Please find in attachment the file.
Thank you
Hi @c.lucchetti
Delete the fixed - fixed releases from these bars.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
