Hi everyone, is there someone that can help me to find the issue on the attached model?
I have 8 cables with pre-tension to define to obtain the non-lifting of the primary columns of the structure. This is a oil tool for tubing.
thanks in advance, greetings at all.
Solved by Artur.Kosakowski. Go to Solution.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
THANKS A LOT FOR YOUR REPLY.
GREETINGS
