The program tells me that there is a problem on a node that does not exist in the model.
Why?
Do you have any idea?
Solved by Artur.Kosakowski. Go to Solution.
Check the numbers of calculation nodes.
I renumbered nodes from 1 to ... .
The message refers to a node that does not exist, it is not displayed on the screen and does not even exist in tabl.
I attached the rtd file
Any other ideas?
It does
Any other ideas?
Hold the top edge of the wall that is released at the bottom (e.g. panel 115)?
The first thing is to understand what is the reason for these nodes to be reported. If you defined a linear release on a free edge of the panel then just remove this definition. If you are not able to determine the reason attach the model.
In my case it was just a lability due to a dual definition of releases bonds between the two bars together.
I hope I have explained well the problem.
Greetings
here is my model:
The way to determine the location of reported calculation nodes is shown on the attached picture. They are created at the intersections of bars with edges of panels.
