Discussion Groups
Robot Structural Analysis
Valued Mentor
HoshangMustafa
Node Number
281 Views, 2 Replies
01-26-2013 12:42 AM
Hi
When I hover over a node the node number doesn't display. What should I do?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Node Number
01-27-2013 11:24 PM in reply to: HoshangMustafa
It should also be visible at the bottom of the screen
Try to save the project, restart Robot and open the saved file again.
Artur Kosakowski
Valued Mentor
HoshangMustafa
Re: Tie beam on ground
01-28-2013 02:49 AM in reply to: HoshangMustafa
Hi
I Found it in the Display-Nodes-Hide Nodes
It was checked
Thanx
