Nodal Constraints/2nd Order Analysis/ Bar Releases
Autodesk,
1) We need PROPER documentation for the entire software
2) Make it possible to constrain motion among multiple nodes without explicit use of master and slave nodes, it seems only possible to make rigid constraints between nodes which causes loss of important info because the rigid links are so stiff.
3) The program seems to have difficulty with 2nd order analysis especially with the addition of bar releases. Even with the multithreaded solver and dsc solver activated it is difficult to get the right answer out of it. Proper documentation would most likely help with this
