Discussion Groups
Robot Structural Analysis
Valued Mentor
58 Kudos
No Supports
153 Views, 2 Replies
06-07-2012 02:33 AM
I have a tower sitting on a raft with elastic parameters but I get a warning that there are no supports. Is this normal or am I missing something. Thanks in advance.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Product Support
1,305 Kudos
Re: No Supports
06-07-2012 03:16 AM in reply to: AJA14
It is normal if there is no phisical support in model.
Elastic ground is not treated by verification as a support.
Rafal Gaweda
Valued Mentor
182 Kudos
Re: No Supports
06-10-2012 02:36 AM in reply to: Rafal.Gaweda
You can use elastic foundation on a panel but don't forget some kind of lateral restriant.  i.e. block UX, UY.  The elastic spring is in UZ.  Depending on the model may need to block RZ too.
Tony
