A quick query, I am looking to use Robot to check a stypical slab for moving mobile crane loads, and i though running a few lines of crane movement across typical spans will do the trick, however, I can not seem to find the option for moving loads. I know that it is suppose to be in Loads=> special loads => moving loads, but as you can see from the attachment, it is not there... any ideas?
@lee24k Artur Kosakowski edited the topic for better findability
Solved by Rafacascudo. Go to Solution.
Solved by MUHANNAD.ABU_ABDO. Go to Solution.
There's no option of moving load in building model !
Im sorry, can you please clarify? Do you mean I should goto the "Loads" lay out tab? I have tried that, and the option is still unavailable.
No .. you must try with frame 3d or shell design .. there's option for moving load in this choice
That's what i mean ... in the frame 3d there's option for moving load
Tools/customize/customize menu/Loads/Special loads and click on moving to turn it into green
Rafael Medeiros
or you can change the model to a shell (Geometry > Structure Type).
