Hello
i have model with static load + water uplift
i consider most of load as auxiliary load ,
and calculation two main combination load see pic 1
with nonlinear analysis options see pic2
but (No convergence of nonlinear problem)
i don t know the reason
kindly find attached file
Solved by Artur.Kosakowski. Go to Solution.
Out of curiosity (before investigating the model) - do you expect (allow) for any uplift within the raft foundation of a building? My assumption would be thet it should be pressure on the soil below for the entire area of the foundation.
I used non linear analysis to cancel tension force on soil springs , and i tried this option in other project without any problem ,
but in this case i will increase thickness of raft until raft weight is larger than water uplift but i still have the same problem
Regards
You can perfectly anchor your raft in the soil and then have some situations there is no pressure on soil. Eg: having enough OW for a normal level of undergroundwater, but need to anchor when water raises an exceptionnal level.
I'am currently doing it near Paris. Raft 60cm and micropiles to make the rest. Otherwise I should have had a 1.00m raft.
What I personly wouldn't do is to have something not equilibrate by OW with normal conditions (ie: always with anchors in tension).
What's your experience guys on that in other countries?
The solution is to increase the tolerance a bit (e.g. 5e-3). Mind to run model generation before launching calculations.
Thank you Thomas.
i am getting the same error in a simple model, can you help me? file is attached
