Hey
My first and very simple 2D Frame in ROBOT.
I get the No convergence of nonlinear problem error when analysis. It is part of my 2. semester project. All is calculated by hand, and i am just trying to see if i can get the same, or just about, results in ROBOT.
The model is attached.
Regards
Sune
Solved by Rafacascudo. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Do you really need to use a cable element for the diagonals , or just a "tension only" bar?
Rafael Medeiros
define as a standard bar element and ...
Rafael Medeiros
Although ,after 15 years (v13.5) of practice and still learning, it´s Not so steep! Maybe the easiest one to learn and operate by far!!
Rafael Medeiros
select the bar you want the results ,then click on menu results/Detailed analysis...
or you can have it also through tables . Right click anywhere / tables.../Forces
and if you need more information in your tables , right click anywhere on table area and click on table columns
Rafael Medeiros
