Show only
Search instead for
Connections design to new codes and new methods is considered implemented through the partnership with IDEA Statica. Please see more information in this thread.
The status change refers to the Connections Code highlighted in the origin of this idea (it helps prioritize if ideas are more specific about the feature proposed). For connections design for US/CAN codes we are be relying on the existing partner solution that works on top of Robot (and also Revit for easier design connectivity to detailing and fabrication. Please see this use case for use with google-translate https://blogs.autodesk.com/villagebim/2021/05/temoignage-le-bet-dynatec-son-worflow-en-charpente-met...).
For other types of codes, some are yet to be updated, indeed. I'll make you involved if that's ok for you.
