Hello Gentlemens,
Im kinda new in the Structural world and also in Robot as a user.
I got one question, is it possible to draw a L-profile under the Z-profile like in the picture. How does Robot calculate on
section class 4 according to the Eurocode (Swedish standard)?
I hope this is possible and got an easy way to define this type of problem.
Best Regards
Safet
Solved by Artur.Kosakowski. Go to Solution.
If you mean replace it with a line with the corresponding properties then you first need to decide what do you need this profile for (static analysis only, code checking) and what kind of equivalent parameters will be best for the intended task.
How does Robot calculate on section class 4 according to the Eurocode (Swedish standard)?
In the same way as for the general EC3.
