Hi there, I am quite new to Robot and I am trying to analyse stiffness here and I guess something is wrong but I dont know what, I cant get the correct displacement or moments even (displacement is zero). my structure is timber framed with clt panels please help
Try to increase the precision of display of values adding some zeros after the point/comma (0.1234). Job Preferences > Other > Displacements.
That work but I still dont get why it is written Dis 0mm and why are the values negative? Does that indicates the direction of the axis?
I assume that you set the diagram scale as 0 ..
.. and the direction of the local Z axes of the horizontal panels are upwards whereas the actual displacements are downwards.
