Discussion Groups
Robot Structural Analysis
New Member
jihanjulaihi
need helps understanding results
168 Views, 3 Replies
01-09-2013 03:05 AM
Hi there, I am quite new to Robot and I am trying to analyse stiffness here and I guess something is wrong but I dont know what, I cant get the correct displacement or moments even (displacement is zero). my structure is timber framed with clt panels please help
Please use plain text.
Product Support
Artur.Kosakowski
Re: need helps understanding results
01-09-2013 03:28 AM in reply to: jihanjulaihi
Try to increase the precision of display of values adding some zeros after the point/comma (0.1234). Job Preferences > Other > Displacements.
Artur Kosakowski
New Member
jihanjulaihi
01-09-2013 03:44 AM in reply to: Artur.Kosakowski
That work but I still dont get why it is written Dis 0mm and why are the values negative? Does that indicates the direction of the axis?
Product Support
Artur.Kosakowski
01-09-2013 05:22 AM in reply to: jihanjulaihi
I assume that you set the diagram scale as 0 ..
.. and the direction of the  local Z axes of the horizontal panels are upwards whereas the actual displacements are downwards.
Artur Kosakowski
