Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
need helps understanding results
3 REPLIES 3
jihanjulaihi
299 Views, 3 Replies
Hi there, I am quite new to Robot and I am trying to analyse stiffness here and I guess something is wrong but I dont know what, I cant get the correct displacement or moments even (displacement is zero). my structure is timber framed with clt panels please help
3 REPLIES 3
Try to increase the precision of display of values adding some zeros after the point/comma (0.1234). Job Preferences > Other > Displacements.
Artur Kosakowski
That work but I still dont get why it is written Dis 0mm and why are the values negative? Does that indicates the direction of the axis?
I assume that you set the diagram scale as 0 ..
.. and the direction of the  local Z axes of the horizontal panels are upwards whereas the actual displacements are downwards.
Artur Kosakowski
