Hello, everybody. I need quick advice:
I'm using RSA pro 2012 x64 (25.0.5.3857) student version and having problems with claddings, panel drawing and load distribution regions.
I am unable to make any cladding, all what I get istransparent auxiliary objects, don't matter, what shape i'm drawing.
Secondly, sometimes then I draw panels, ROBOT makes panel, but it's transparent, don't matter what display options or thickness I choose.
And finally, then I send my project to my classmate, (with x86 RSA pro 2012 version 25.0.0), he makes claddings and sends to me I can't genereate load distribution regions. Even if I ignore bars at load distribution options, I get forces ignored bars.
I tried to Install service pack 5, but I get message, that I'm using the up-to-date program version. I am using Windows XP pro x64. Don't have time to download 2013 ROBOT...
Create a small model where this situation can be seen and attach it to the message so that we can check what have you done
take a look. This time panel created sucessfully, sometimes I just need to restart Robot to draw Panels and openings.
However I was still unable to create claddings. I ignored TRON 60x5 bars at that umbrella, and random bars at frame structure, but nothing happens - nor the loads come to columns from claddings (I should have created another load case to see that, just delete self weight load from structure to see that) nor load distribution regions were created...
Wanted to download RSAP 2013 and saw, that SP3 for windows xp x64 pro is required (mine is SP2) .
Can't see what are the requirements for 2012 version, but may this be the reason?
By the way - is there RSAP 2013 x64 version at student software sector? Because I only available to download 32bit version
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Not-a-Body-get-AGAIN/m-p/3289851/
and follow the recommendation from the message 4 (switch off use of the geometrical kenel).
