I have tried the NBCC equivalent static seismic analysis method in Robot. The result is not same as manal calculation. Please see attached calculation notes, I marked some question on it.
Peijing
Solved by peijingx. Go to Solution.
Please find attached model and hand calculation.
peijing
I am afraid you are right.
We will correct it asap.
This should be corrected in next service pack.
This is what I meant.
Already corrected in Service Pack 3 for ARSA 2014
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22436870&linkID=13140816
