I have problem modelling a moving load, im doing a arbitrary vehicle, when I asign a value for FZ its later reduced when I look in the geometry section. I wonder if there is a factor somewhere reducing this value. I would like to use the asigned FZ-value for my calculations , not the reduced one.
Anders
Only if you define some reduction coefficients in the parameters of the route. Reading your question I don't think you defined them. Most likely the load has not been applied in full - I need the file to tell more. Please indicate which vehicle position to look at.
Load direction should be vertical.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
