I'm facing the problem of solving non-linear combinations with moving loads :
I can perfectly solve the moving load case in non-linear analysis but I dont have any results if I combine it with other static load cases.
Although I've read on a forum topic here that it's not a feature, It seems strange that solving non-linear moving load cases is possible but combinations of it with static cases isn't.
Considering it's not possible, I'm trying to export components of a moving case to static ones but the embeded function in RSA is messy as it takes every empty case number ...
Hence, iI'm trying to write an VBA macro that does the job and starts at the specified case number.
Problem is I can't get to copy load records to the static case.
First attempt of code's here :
Public Sub movToStaticCases(movingCaseId As Integer, firstStatic As Integer) Dim RobApp As IRobotApplication Set RobApp = New RobotApplication Dim RCS As IRobotCaseServer, robCase As IRobotCase, movCase As RobotMobileCase Set RCS = RobApp.Project.Structure.Cases Set robCase = RCS.Get(movingCaseId) If Not robCase.Type = I_CT_MOBILE Then MsgBox "Case " & movingCaseId & " is not a mobileload case" Exit Sub Else Set movCase = robCase Dim iComp As Integer, compRecs As RobotLoadRecordMngr, compRec As IRobotLoadRecord, iRec As Integer Dim newCase As RobotSimpleCase, newRec As RobotLoadRecord, oldRec As RobotLoadRecord If movCase.Components.Count = 0 Then MsgBox "Moving load case contains no components, please make sure to run the computation to generate components" Exit Sub End If For iComp = 1 To movCase.Components.Count 'Create the new static case If RCS.Exist(firstStatic + iComp - 1) Then RCS.Delete firstStatic + iComp - 1 Set newCase = RCS.CreateSimple(firstStatic + iComp - 1, movingCaseId & "/" & iComp, I_CN_EXPLOATATION, movCase.AnalizeType) Set compRecs = movCase.Components.Get(iComp).Records For iRec = 1 To compRecs.Count Set oldRec = compRecs.Get(iRec) Set newRec = newCase.Records.Create(oldRec.Type) 'Next : do i need to copy every parameter one by one or is there a simpler way Next iRec Next iComp End If End Sub
Thanks.
Regards
check with this:
Dim RLCom As RobotLoadRecordCommon
Dim rec As RobotLoadRecord
Set rec = isc.Records.Get(irec)
Set RLCom = isc.Records.Get(irec)
if RLCom.IsAutoGenerated then.....
Thanks for your quick answer, but would you care to elaborate a little more ?
I'm using RSA 2012 and I can't find the class RobotLoadRecordCommon but only the corresponding interface.
From what i see IRobotLoadRecordCommon only contains the "isautogenerated" field and I don't see the point of using this.
Maybe i've not been clear about what I'm trying to achieve : I understand that LoadRecords contains all the parameter to a specified load (such as a point load on a bar, at x=... with fx=... etc...).
I'm trying to extract a case's components to a single static case, and to achieve this, I'm trying to copy the load record of my moving case's component to the newly created case.
Thank you again.
Yes, you have to
newRec.Objects.AddText oldRec.Objects.ToText For iii = 0 To 14 newRec.SetValue iii, oldRec.GetValue(iii) Next iii
(Autogenerated has nothing to do with it. Sorry)
Thank you, it seemed more complicated than that.
Although, I still have an error :
At the line :
I get the following error (translated from french) : "The method "GetIdsOfNames" of the object "IRobotLoadRecord2" has failed".
If I try to spy on the record, I get "automation errors" as value for the Objects, and ObjectType properties.
Any idea about that ?
Regards.
I looked deeper and the answer is : rather not possible, you have to convert them in Robot.
The records generated are different records (types) than normal ones used by user.
These records have no objects so it will be hard to convert them correctly by API.
Here is example for point force load in moving load on bar(s) - new nodes must be generated etc
Dim RobApp As IRobotApplication Set RobApp = New RobotApplication Dim RCS As IRobotCaseServer, robCase As IRobotCase, movCase As RobotMobileCase Dim Newnodenumber As Long Set RCS = RobApp.Project.Structure.Cases Set robCase = RCS.Get(movingCaseId) If Not robCase.Type = I_CT_MOBILE Then MsgBox "Case " & movingCaseId & " is not a mobileload case" Exit Sub Else Set movCase = robCase Dim iComp As Integer, compRecs As RobotLoadRecordMngr, compRec As IRobotLoadRecord, iRec As Integer Dim newCase As RobotSimpleCase, newRec As RobotLoadRecord, oldRec As RobotLoadRecord If movCase.Components.Count = 0 Then MsgBox "Moving load case contains no components, please make sure to run the computation to generate components" Exit Sub End If For iComp = 1 To movCase.Components.Count 'Create the new static case If RCS.Exist(firstStatic + iComp - 1) Then RCS.Delete firstStatic + iComp - 1 Set newCase = RCS.CreateSimple(firstStatic + iComp - 1, movingCaseId & "/" & iComp, I_CN_EXPLOATATION, I_CAT_STATIC_LINEAR) Set compRecs = movCase.Components.Get(iComp).Records For iRec = 1 To compRecs.Count Set oldRec = compRecs.Get(iRec) If (oldRec.Type = I_LRT_MOBILE_POINT_FORCE) Then Set newRec = newCase.Records.Create(I_LRT_NODE_FORCE) Newnodenumber = RobApp.Project.Structure.Nodes.FreeNumber RobApp.Project.Structure.Nodes.Create Newnodenumber, oldRec.GetValue(I_MPFRV_X), _ oldRec.GetValue(I_MPFRV_Y), _ oldRec.GetValue(I_MPFRV_Z) newRec.Objects.AddOne Newnodenumber newRec.SetValue I_NFRV_FX, oldRec.GetValue(I_MPFRV_FX) newRec.SetValue I_NFRV_FY, oldRec.GetValue(I_MPFRV_FY) newRec.SetValue I_NFRV_FZ, oldRec.GetValue(I_MPFRV_FZ) End If Next iRec Next iComp End If
I did look a little deeper to and came to the same conclusion that mobile load records don't have objects.
But I found that mobile components have a set of mobile records and a set of normal ones. If I keep only the normal ones, I have some records with objects, but the majority of them don't (Though all records have the right set of forces).
Your solution doesn't work because the value returned with the index I_MPFRV_X (or the 2 others) does not contain the coordinate but the force applied on the X axis. I've looked at the values at the indexes 0 to 14 and I dont see any relevant coordinates in theses values.
This part of the API really doesn't seem very clean !
Regards.
Check coordinnates of these "normal records" - you may easily see them in combinations table, rather not usable in your case.
Make double check
_X returns coordinate (used to create nodes in my code), _FX force
Hint
I_NFRV_FX = 0
I_MPFRV_FX = 3
I told you : mobile records are not standard ones.
Ok, thanks for your help all along this topic but this thing has become quite complicated for the things I've been trying to achieve.
I guess I'm gonna try to find some easier way to run my computation !
hello,
do you know how to make combination of automatically generated load case and some other load case. I was trying but i didn't solve it.
If this isn't possible, is there even a way to present sum of these results together?
thanks
